X-Trail (T32) red engine warning light
I need some help with my 2015 Nissan X-trail.
The red engine warning light came on after starting engine in cold weather (-20°C / -4°F) with the following trouble codes: P0226 Throttle/Pedal position sensor P2263 Turbo/Supercharger Boost System P0380 Glow Plug/Heater Circut A P0560 System voltage malfunction P1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction Bank 1 Sensor 1 0071 Unknown fault code P0657 Actuator Supply Voltage P0141 O2 Sensor Heater Circuit Malfunction P0627 Fuel pump control circuit Glow Plugs are new, O2 sensor is quite new. I also checked the relay nro 85 in engine compartment and it is ok (most of the trouble codes seems to be related to relay nro 85). I have driven the car and it's behaving normally. Any suggestions? |
| All times are GMT -5. The time now is 07:04 AM. |
