motor problems
i have a 87 nissan d21 hardbody with a z24i motor and 5 speed. the motor has 240k on it and rebiult once befor and now it has a pretty bad knock and runs realy bad and im moveing to alaska in march and i need to know if i should find a new motor or if i should keep it and fix it. and any kind of advice will help
RE: motor problems
Really is going to matter what's wrong with it .... if it's knocking real bad, try to find a used head. Welcome to the forum.
RE: motor problems
thanks man the worked but now theres a new problem. the old starter went out and i replaced it with a new one and it started fine for about 2 days then it stoped and will start if i push start it and i have gone through all the wireing and made sure it was hooked up right. i replace the ignition relay checked all the grounds and it still wont start and i cant figure out what the hell it could be.
RE: motor problems
Those cars have a history with ignition switches going bad.
