1990 240 racecar HELP!!
1990 2.4 fastback 5 spd
I was wondering if anyone makes a cam for the 12 valve head, or if a 91-94 head would work on the 89-90 block. if it does, does anyone make a camshaft kit for the 16 vlave head? any info on putting bigger valves in either heads, porting work, or anything else i can do to get more power out of this engine? does anybody make a low cost headder for this car? -(non coated) I am planning on running this car on dirt track, but class rules designate origional engine for the car, so no engine swaps. any help or info would be VERRY appreciated! |
RE: 1990 240 racecar HELP!!
I believe this is the cam you are looking for.
http://www.mossyperformance.com/product/?id=4418 |
thanks for the help.. you don't happen to know how wide of a tire i can fit on the rear?:eek:
