240SX Won't start
Hello Everyone,
I need some help! I have a 1993 Nissan 240sx convertible (automatic) The car will not turn over, battery checks out 100% ok. So I am thinking it is one of three things. Bad starter Bad Park/neutral switch Bad starter relay My question is, where is the park/neutral switch located? And how do I access it? Thanks, |
RE: 240SX Won't start
seems like autozone.com website had a place on their website where you could look up the location of stuff like that.have yu tried jumping across the solenoid at the starter with a remote starter switch? would eliminate the starter and batt and cables.?
is it cranking? It may be a fuse. always check the smallest things first.
Park/neutral switch is on the transmission.
I have the same exact car and you should invest in the factory manuals. They're expensive, but worth it.
DO you have lights or radio? If not, check the battery cables. remove from terminals and clean. That'll do it I bet. Good Luck! |
Fuel Pump relays are a common failure in 240's..... would lookin into that.
try looking at the ground for the battery or the starter, make shur the are clean and tight.
i had the same thing happen to me. -DICK- |
