| HXC_Nismo |
Nov 17, 2007 10:11 PM |
RE: brakes
i am a strong believer in 300zx z32 twin turbo front 30mm 4 piston calipers with stainless brake lines, hawk pads and cross drilled andslotted rotors and you will stop on a dime and this brake upgradeusually cost under$500. i have these on my rb26 98 240sx and theydramatically improved my stopping power and they bolt right onto your 240sx the only think you have to do is either remove the splash shield or trim the splash shield behind the rotors. good luck if you have any questions on this brake swap just ask and ill help you as much as i can
