ca18det maf air flow sensor
i touch, by mistake, my ca18det 200sx MAF sensor. i know is a huge mistake, i know. Now the car is in safe mode. revving until 2000rpm only. I use maf sensor cleaner and i remove the negative battery cable for 24hrs. i measured the signal voltage (A,D wires) and is 3.424-3.427V at idle, when i rev is moving +0.003V only. what else i can do exept of replace the sensor?
maf part number, 22680 58a00. i found that 58a10 is also suitable. i talk with nissan and told me that 61a01 is the newer version of it. |
| All times are GMT -5. The time now is 08:32 AM. |
