-   Nissan 240sx and Nissan 200sx (https://nissanforum.com/forum/nissan-240sx-nissan-200sx-18/)
-   -   Cam and piston clasification (https://nissanforum.com/forum/nissan-240sx-nissan-200sx-18/cam-piston-clasification-580/)
atc200sx Sep 18, 2005 06:07 AM
:eek: I cant decide witch cam shafts use for planing 400 BHP engine: 12.09 lift 264 deg. dur
12.7 lift 275 deg. dur
13.36 lift 275 deg.dur
11.2 lift 260 deg.dur
11.785 lift 266 deg.dur
[:-] and the same is with pistons:86.5mm 8.5:1
86.5mm 9.0:1
planing- 87mm 8.5:1
87mm 9.0:1 on engine is going T3 turbo!?
Will be glad if u lads help me out. [:)Thanks.
Schmeb Sep 18, 2005 08:07 AM
RE: Cam and piston clasification
Take your engine specs to some one that does camshaft grinding.
They can grind a camshaft to suit the motor and produce the horsepower that you want
atc200sx Sep 28, 2005 08:37 PM
[8D] Yea that will cost another grand or more. Ill be glad just to get some of these cams from USA-cause im just starting now all my project INSSANE :D I just wanna get some more information bout them!?!?!?!?
