No spark
Well I picked up a car yesterday, and bought it under the impression that it had so spark. I paid $800 for it, and it's a 91 coupe. There are only 4 thinks that immediatly come to mind that could cause this:
1) Bad crankshaft position sensor 2) Bad camshaft position sensor 3) Bad distributor 4) Bad ecu I pulled the aftermarket security system/remote start out, and taped all the wires that had insulation stripped back, and soldered all the wires that had been cut then heat shrunk them. Where do I go from here? The electronics all work, and the hud works, it just doesn't spark. It did come with aintake manifold complete with everything but the injectors, exhaust manifold, downpipe, alternator, some belts, distributor, and some other odds and ends. |
RE: No spark
Anyone wanna help me out??
