-   Nissan 240sx and Nissan 200sx (https://nissanforum.com/forum/nissan-240sx-nissan-200sx-18/)
-   -   oil leak 200sx (https://nissanforum.com/forum/nissan-240sx-nissan-200sx-18/oil-leak-200sx-2139/)
u2shibby@yahoo.com Jul 16, 2006 03:43 AM
oil leak 200sx
anybody know about any problems with an oil leak on a 200 sx. It is around the belt and alternator. I think it loses most when driving it. It is shooting on the belt and getting all over I can't pinpoint it. But it is there. the car has 120000 miles it is 2.0L anything something. let me know thanks tim
AdriloverSR20 Aug 21, 2006 05:05 PM
RE: oil leak 200sx
You might want to check your valve cover gasket. you might need a new gasket and most probably that will be the problem...
2dr_sentra Aug 21, 2006 06:17 PM
RE: oil leak 200sx
where your talking about i would imagine its the v/c gasket, if so when changing it put paper towels in the plug holes to soak up the oil that is going to leak out then removing/replacing it.
ridgerunner1965 Aug 22, 2006 09:21 AM
RE: oil leak 200sx
not sure if the 2.0 is the same as the 1.6 but i had 2 1.6 engines with what sounds like the same leak. it was the crankshaft seal behind the harmonic balancer. had a heck of a time diagnosing it tho. i purchased a ultraviolet leak detecter fron jc whitney and found it easy then. the first car i had the leak on i think i may of caused it by tightening the belt to tight. let us know what happens.
