-   Nissan 240sx and Nissan 200sx (https://nissanforum.com/forum/nissan-240sx-nissan-200sx-18/)
-   -   reset check engine light (https://nissanforum.com/forum/nissan-240sx-nissan-200sx-18/reset-check-engine-light-3546/)
xxxxxquest Apr 14, 2007 09:28 PM
I have a 1995 240sx and recently the check engine light is on. I wanted to turn if off and see if the lights comes up again so I tried to disconnect the battery but didn't work. Does anybody know any other way to reset the check engine light?
thanx
HXC_Nismo Apr 15, 2007 04:45 AM
RE: reset check engine light
go to autozone and have them check the codes for the check engine light also you can disconnect the negative battery cable for ten minutes and that usaully resets the ecu.
Cajun02 Apr 26, 2008 12:17 AM
Maf Sensor or 02 sensor could be bad could be a faulty seal on your gas cap
kibatheloanwolf Jun 22, 2008 01:32 PM
i know how to reset it on a chevy XD
Cajun02 Sep 11, 2008 08:08 PM
you might have to use a code reader with the reset button Autozone wont reset it for you
