1987 300zx noise
Old Oct 10, 2007 | 09:53 PM
87_300zx's Avatar
Default 1987 300zx noise
I am hearing an intermittent clunk from the rearend when I am driving the car. I believe it to be the needle bearings on the u joint but I don't know for sure. Any suggestions?
Old Nov 14, 2007 | 10:25 PM
dman300tt's Avatar
Default RE: 1987 300zx noise
i had a noise like that in a couple of z's i owned,and 85 and 84 i found out that was the rear differential mount had actually seperated causing on take off or hard shifting to cause the loud clunk,but mine was more of a knock than a clunk.you can check this by putting it over apit and have someone hold the brake and step on the gas,you'll see it seperate and lift up and hear the knock when it comes back together when the weight falls back on it.my 2 cents
Old Jun 30, 2008 | 08:51 PM
yogidapimp58's Avatar
if u still have the noise problem. its your wheel bearings. my car made the same noise, because my wheel bearing was bad. and best to do both sides. the back you have to take it to someone. the fronts are easy.
Old Jun 30, 2008 | 11:43 PM
nismo89Z's Avatar
yeah i had the same problem with my 87 & 89, i had gone to a muffler shop to get my exhaust set up...fortunatly i had a friend who worked there and he warned me about it. he said he would weld it for me but i never went back though.
Old Aug 7, 2008 | 10:06 PM
Roberto's Avatar
that noise is gonna be your rear axle
Old Sep 4, 2008 | 07:44 PM
nizmofool's Avatar
OR MAYBE ITS MAKING THAT NOISE BECAUSE ITS SO DAMN OLD!!!??
bumble-bee
Mar 30, 2012 02:33 AM
eddieb
Mar 4, 2011 12:48 PM
slimer
Jul 16, 2005 10:45 PM
slimer
Jul 16, 2005 09:02 PM
simon
Jun 18, 2005 10:44 AM
