Common problems with the 300ZX
This may not go here, but since it is specifically related to the 300ZX, maybe it does.
Common Problems |
RE: Common problems with the 300ZX
hmm..excellent informative post soaring.
Like what? Timing Belt? When should it be replaced? I'm looking to buy a 300 ZX...anything I should watch out for?
this link should prove to be helpful...it kind of blends in with soarings post..
http://www.zeeyalater.net/comprob1.htm#tail%20lights |
Many things to look for on the TT.. leaks under the car Turbos ? Smoke from engine or turbos,,,? Last time the timing belt was replaced. Old vaccum hoses are the worst.. Boost leaks everywhere...
TXQ45 |
well, with any turbocharger when the internal seals go bad, it will leak oil which causes smoke.
| All times are GMT -5. The time now is 02:59 AM. |
