HELP!!!! WHAT HAPPENED!!!
I just got my timing belt, waterpump, and termostat replaced on my 1990 Nissan 300zx AT N/A. Now when I accelerate, theres a clicking noise. Also its hitting 4000-5000 RPM easily but it accelerates very slow. What is wrong?!?!
RE: HELP!!!! WHAT HAPPENED!!!
you should start by checking the oil level if it is low enough the lifters will make a clicking noise also check to make sure nothing is in the way of your pullies and belts. Check the A/T fluid level too that might be your accel problems. other wise you might have burnt clutches in your trans.
did u get it fixed?
i just had the same set of things done to my '93. will be getting it back tommorrow, will let u know how mine's doing. |
