Hot air
I have a '86 300zx non-turbo. Ive got a problem with hot air blowing in the car at all times, it doesnt matter if the air is on cold, hot or if the fan is on or off. Im planning on swapping the motor to a 350 cid chevy motor but I need some suggestions to fix the hot air until I can do the swaps. Thanx for any help.
RE: Hot air
hey man, first up i dont mean to sound negative but why would you buy an import then put a ****ty domestic motor in a perfectly good nissan chassis.
and to answer your question, First check your resistance on your switch. if its not that check the blower motor and see if its not shorted. Hope i could be of some help. |
RE: Hot air
yeah sounds like the blower motor, its a cheap fix.
Baulkin - please try and keep everything here in good taste. |
RE: Hot air
sorry for any kind of derogatory comments left by myself in the previous post.
RE: Hot air
ORIGINAL: baulkin hey man, first up i dont mean to sound negative but why would you buy an import then put a ****ty domestic motor in a perfectly good nissan chassis. and to answer your question, First check your resistance on your switch. if its not that check the blower motor and see if its not shorted. Hope i could be of some help. |
| All times are GMT -5. The time now is 04:43 AM. |
