smells like gas
Had the same problem and looked under the hood and found that a clamp for my fuel reg came a little loose... Let the car run for a couple of minutes with the hood up and it will hit you hard with the smell.. You might have to open the throttle from under the hood so the gas can have some more pressure.. Good luck.
robinlox
Useless Posts
Sep 1, 2006 04:35 AM
