smells like gas
ok diz iz my 300ZX ... so im worried cuz whenevah it start it or drive it ya can smell da gas . is dat mean i have a gas leak somewhere or do i have an exhaust leak ?
RE: smells like gas
Could be either ..... most of the time it would be an exhuast leak... but never can tell with an older car... best bet it to get up under your car and check it out.
RE: smells like gas
thanx
RE: smells like gas
Had the same problem and looked under the hood and found that a clamp for my fuel reg came a little loose... Let the car run for a couple of minutes with the hood up and it will hit you hard with the smell.. You might have to open the throttle from under the hood so the gas can have some more pressure.. Good luck.
| All times are GMT -5. The time now is 09:03 AM. |
