-   Nissan 300zx (https://nissanforum.com/forum/nissan-300zx-17/)
-   -   t-tops are leaking!!! (https://nissanforum.com/forum/nissan-300zx-17/t-tops-leaking-4922/)
knobelkyle May 4, 2008 07:54 PM
my t-tops on my 1990 300zx are leaking! what can i do to stop it?!
nismo89Z May 7, 2008 02:07 PM
RE: t-tops are leaking!!!
check the weatherstrip on the t-tops replace it if it's worn. thats usually the biggest problem with leaky t-tops...clean the surface before replacing it though that way u have an easier time applying the adheasive to the strip.
knobelkyle May 7, 2008 10:24 PM
where do i get the stripping?
nismo89Z May 8, 2008 11:10 AM
you can buy it at any autoparts store if they don't have it then you would have to go to the dealer.....its worth it though i had the same problem and all my cd's got messed up because of it. and if it gets into your carpet then its gonna be stinky for a while
knobelkyle May 9, 2008 10:12 PM
awesome thanks! you wouldnt happen to know how to turn down the idle speed on a 1990 300zx? i tried the screws on the throtle body but all that did was made my pedal sticky... any words of wisedom?
nismo89Z May 24, 2008 08:10 PM
i know on my models it was on the idle air control valve. i'm not sure where its on the z32 models but if u can locate it that would be your best bet...i don't remember if u screw out orin but give it a try and i'm sure you'll get the result you want.
