-   -   07 Altima and Trans problem (https://nissanforum.com/forum/nissan-altima-10/07-altima-trans-problem-3847/)
nygiants Jun 21, 2007 07:14 PM
I have an 07 Altima SE 3.5. After 2 months I had to have the transmission replaced and the computer. When I let up on the accelerator the car slows down a lot. The service department says this is normal. I don't remember it doing this when I bought it. Anybody have any issues with an 07 Altima transmission and does your car slow down like that?
kauaid Aug 31, 2007 07:54 PM
RE: 07 Altima and Trans problem
I have a 07 2.5 SE, the trans is doing something strange, dealership says it's normal for the CVT but I don't know about that. When I'm pulling out, if I stomp it, and slack off a little,when the rpms reach 4-5 it'll stay there reving for a little while then come down slowly. I even took my foot off the pedal and it kept revving. Happened several times, doesn't sound normal to me. I guess if it takes a dump, I get a new trans.
D
brett5150 Sep 9, 2007 02:27 AM
I don't know if this is any help but I thought id let you know
Copied from consumerguideauto.com
Electrical problem: The exhaust manifold heat shield on early production cars cuts the oxygen sensor wires, resulting in lack of engine power.
Engine stalling: A problem with the ignition coils causes stumbling during light throttle cruise or stalling at idle, requiring installation of a resistor between the coils and spark plugs.
Burnnout Sep 10, 2007 01:27 PM
:eek:That has nothing to do with their issues ...... sounds like they are just not use to having cvt ....which is very common because of the unnaturalness of it.
