1993 Nissan Altima Wont Start
Old Dec 13, 2006 | 08:39 PM
peterr22's Avatar
Default 1993 Nissan Altima Wont Start
I have a 1993 Nissan Altima 2.4L 5-Spd
It has power
Im pretty sure I hear the fuel pump prime.
It sounds like im not pressing the clutch, but I am. I
know i have a clutch fluid leak around the peddle so i think it may have shorted the relay or something.
Im no expert though thats why Im writing on here.
So what should I check???
Thanks
Old Apr 1, 2007 | 07:06 PM
mattsthru's Avatar
Default RE: 1993 Nissan Altima Wont Start
I would say get that leak fixed. Because if its leaking then there's bound to be air bubbles in the system. Which would cause clutch failure. I don't think the sensor would short because it's only two wires that make contact. You could rewire them to make the ecuthink the clutch is depressed but make sure it's in neutral. I don't think you can drive it with the sensor rewired but you can tell if it's the problem or not. Hope this helps.
Old Apr 2, 2007 | 02:29 PM
does the motor turn over but wont even stumble or try to start? cause if its that it could possibly be a bad cap and rotor or your not getting power to your ignition. please give us more info on what its doing unless i just guessed right on what its doing.
beazo40
Oct 27, 2009 02:17 AM
treeman7691
Jan 30, 2009 10:30 PM
rgordon
Dec 27, 2005 09:12 PM
rgordon
Dec 17, 2005 12:43 AM
rgordon
Dec 16, 2005 04:28 PM
