2004 Altima stalls after starting in cold
Old Nov 28, 2007 | 07:57 PM
2ndnissan's Avatar
Default 2004 Altima stalls after starting in cold
is -25 celsius - car was plugged in so it started well ... idles down after a few minutes ... when I tried to put it in gear it stalled ... added gas line antifreeze ... tried idling it in neutral ... still stalls ... after maybe 5 minutes ... when I pressed the accelerator, it started to run rough, and stalled. am wondering if tomorrow might be a better day, or if I have to give up and send it by tow truck to a garage. thanks for your ideas
Old Dec 3, 2007 | 10:02 AM
Burnnout's Avatar
Default RE: 2004 Altima stalls after starting in cold
What do you mean by "plugged in" ? ..... Sounds like the infamous throttlebody or cam/crank sensor problem. Any check engine light ? There is a new recall (ecu reprogram) for all 03-05 altimas.
Old Dec 3, 2007 | 12:18 PM
Danalog's Avatar
Hey guys,
I have the same problem with my '05 but sometimes it wont start. I had the fuel pump and filter replaced and still the same problem in winter. Sometimes it wont start on the first crank and then it will and idle really rough.
serenamand
Nissan Of Japan Other Models
May 15, 2014 08:31 AM
ophuss
Oct 4, 2009 07:44 AM
woodbutcher1
Jul 14, 2007 08:30 AM
gab1000
Mar 1, 2007 12:27 AM
ophuss
Useless Posts
Sep 25, 2006 11:18 PM
