-   -   93 Altima Rough Idle - PCV/Breather and other questions (https://nissanforum.com/forum/nissan-altima-10/93-altima-rough-idle-pcv-breather-other-questions-3659/)
mushaiq@yahoo.com May 7, 2007 02:17 PM
My 93 Nissan Altima with ~110K miles has been idling rough lately. It drives well without any roughness. I have done the following but the problem hasn't been resolved:
1. New plugs, rotor and distributor cap (note: no new plug wires)
2. New EGR Valve
There is also a lot of oil leakage that I am seeing on the engine. I have read that a blocked PCV valve may cause the leakage and may also cause a rough idle. Hence, after days of labor, I have managed to take the PCV valve out, and found the following issues with it:
1. It had oil in it which dripped out when I held it vertical.
2. The breather separator seems very dirty.
My question are the following:
1. Is there a filter in the breather separator which needs to be replaced? Autozone tells me that 93 altima does have any. Is that correct?
2. Is there a way to clean the breather separtor without taking it off?
3. Could the IAC regulator/vale be a cause for the rough Idle? I took it off but don't see any significant carbon buildup.
Thanks for your reply.
pryde300zx May 7, 2007 04:05 PM
RE: 93 Altima Rough Idle - PCV/Breather and other questions
from my experiance its probably the IACV, had a different vehicle that was having idle problems and that solved the problem entirely
mushaiq@yahoo.com May 10, 2007 01:42 PM
Thanks pryde300zx.
I took off the IACV and cleaned it. I haven't had a chance to put it back on, but should be doing so soon. I'll post my findings later.
