-   -   94 altima stalls frequently!! HELP (https://nissanforum.com/forum/nissan-altima-10/94-altima-stalls-frequently-help-2502/)
ophuss Sep 25, 2006 08:30 PM
I have had this problem for about two months now where my '94 Altima will
start-up drive for about 5 miles and the dashlights will come on and the
engine will not run. After coasting to the side of the road I will wait
for usually 4-5 min and it will start up again and drive fine usually for
at least another 20-30 miles before happening again. At times the wait
for the restart has taken more than a hour.
The shop I brought it to believed it was the fuel pump, therefore replaced
ther pump with the fuel filter and checked the fuel lines, however no
luck.
Next they replaced the distributor and distributor cap because of heavy
corrosion. It stalled on the way home from the shop.
Next time, they adjusted the timing belt. Still no change in stalling
frequency or pattern of stalling tendencies.
The most recent diagnosis from Nissan is EVAP drain clogged and water
stains on ECM, need to start with replacing ECM for
$1162. The tech also
noted a valve cover that was leaking badly and soaking the ignition wires
that could be replaced for
$245. And a knock sensorcode in system for
$660.
I have read various forum posts from around the net describing the same
problem to a T with no solution. Please help i'm at my wits end.
Thanks
ophuss
purple dream Sep 6, 2009 10:06 AM
I have a '95 that is doing the exact same thing, no one can figure it out.
What was your fix?
Milkman11 Sep 6, 2009 08:26 PM
I would replace the valve cover gasket and replace the spark plugs and wires. Excessive oil on the sparks will make the car shut off. I have a lot of oil on my position 4 spark plug and will replace the plugs and gasket tomorrow. Another thing is you should replace the fuel filter (part is usually like 10 bucks) and PCV valve.
patricia19 Sep 15, 2009 04:12 PM
Stalling
I have the same problem did you ever find out the fix 9/15/2009
scuodecut. Sep 17, 2009 03:48 AM
Il s'agit d'un forum intéressant pour tout le monde
purple dream Sep 21, 2009 10:23 AM
I haven't fixed it, it is just sitting waiting for a solution.
Do you have a solid idea?
juliarichard34 Oct 4, 2009 07:44 AM
You are spending to much money in replacing the parts,so its better to have a new car in a same.You will get rid out of the tension.
