94 distributor system id
Old Jul 12, 2008 | 02:03 PM
dfreeman616's Avatar
Default 94 distributor system id
i have a 94 altima i just swapped a 98 engine into, using the electronics from the 94. the problem is, someone stole the distributor, ignition coil, distributor transistor, MAF sensor/upper air box, and some other parts as well as clipping the wires for those items before i got it. so, aside from checking with the dealer, is there a way to distingusih between the hanshin system and the hap system, or does it even matter since i'm going to have to replace the connectors as well?
on another note, is there anyway to swap in the latter module distributor/CMP/transistor/coil from the original car, or does the cam sensor produce a differant square wave signal between the 2 years? looking a the scematics, i can't find a differance that i couldn't wire it in, but i can't find any specs as to what the signale would be. anyone have some FSM's that would show an osiloscope print out for the cam sensors? that would seem to be the only issue to overcome. i know the MAF's produce a differant voltage signal between 94 and the one i have.
LittleHoov
Jun 26, 2007 08:32 AM
joeeb7
Aug 16, 2006 11:40 AM
bushanic
Aug 7, 2006 08:07 PM
houmack
Jun 14, 2006 03:39 AM
Xtina
Dec 15, 2005 12:57 AM
