95 Altima Fusebox Question
The fuse box has three vertical fuses as circled in the first picture on the top. The fuse box diagramprovided on the cover of the fuse box doesn't describe anything about these three fuses, neither does the Factory Service Manual. Could anybody please tell me what they are for?
http://aycu25.webshots.com/image/215...5649341_rs.jpg http://aycu03.webshots.com/image/208...3378696_rs.jpg |
RE: 95 Altima Fusebox Question
The reason they are not listed on the fusebox cover is that they don't fuse up anything. They are just slots for holding spare fuses for when one burns out. Notice how there's one of each color/rating? You can confirm this by removing one and you will see there are no metal contacts inside.
would it be hard for nissan to draw them on the fuse box cover?
ORIGINAL: p0rt0_24 would it be hard for nissan to draw them on the fuse box cover? |
ORIGINAL: HXC_Nismo They're just blanks. |
Thanks to all you guys for the replies. They are indeed spare fuses. Used up one of them to replace a blown fuse.
2003 Nissan Altima Fusebox Diagram
Here is a link to the diagram for the interior fuse box for the 2003 Nissan Altima. I think the 2002 Altima is the same.
http://www.imageurlhost.com/viewer.p...mp6taeltkx.jpg |
2003 Nissan Altima Fuse box
Is there a fuse box under the hood of a 2003 Nissan Altima? If so which spot controls Cigarette Lighter Adapter?
It easy very easier to see and find the fusebox if it wii be in the vertical direction. If in future we need to change and some technical problem happen so we can easily find out and repair it.
Sorry its totally a technical question.and I'm not that much expert in this so its better to go and meet and tech guy he will definitely help you.But I will surely try to find it out.
| All times are GMT -5. The time now is 12:18 AM. |
