-   -   Airbag Dash Light Flashing (https://nissanforum.com/forum/nissan-altima-10/airbag-dash-light-flashing-3788/)
Spinophile Jun 9, 2007 04:50 PM
So I stalled a new stereo head unti in my 2005 Altima today and now a red airbag light (a man buckled in with the airbag deployed) is flashing. Why? How would I fix this? Any ideas?
I am guessing it has something to do with the fact that I had to remove the panel and disconnect the "Passenger Airbag ON/OFF" indicator below the A/C controls.
Thanks,
Travis
p0rt0_24 Jun 9, 2007 08:14 PM
RE: Airbag Dash Light Flashing
maybe you should reconnect it, it might be not be tight enough
Spinophile Jun 9, 2007 08:56 PM
I've tried, but no success...
Thanks though!
Spinophile Jun 10, 2007 09:12 PM
Okay, well, I guess I try a different Nissan Forum.
GeneO Jul 4, 2007 04:00 PM
I own a '99 Altima with the similar problem. I have checked all of my connections and they seem to be okay. Does anyone have any other ideas on how to eliminate the blinking light?
Gene
Spinophile Jul 4, 2007 04:56 PM
Actually, I was told on another Nissan Forum that only a Nissan Dealer can correct this. I spoke to the dealer ship I bought my vehicle from and they confirmed that. Unfortunately, if the vehicle is turned on while an airbag indicator or other airbag sensor is disconnected, the cars computer system trips and "error code". The only way to correct this is to have the computer system hooked up to a diagnostic system that will clear the error code. The dealership offered to do this for me at $49.95, but screw that. I can live with a flashing light until I have to take the car in for some other service.
In you case, is you have not done anything to cause the light to come on, such as disconnecting indicator lights or airbag system, you may actually have a problem that need to be repaired in order for the airbags to deploy in case of an accident.
Good luck and sorry for the lack of a DIY repair.
jhav Feb 21, 2008 07:36 PM
Spinophile...you seem to be dead right! My 350Z has the same problem and today it is back in the dealership, wait for it...GETTING A NEW LOOM INSTALLED.
brubaker Aug 27, 2008 03:52 PM
some car parts stores have the computer system to check error codes and can clear it all you have to do is ask and most places dont charge. if you go to orileys auto parts they will gladly do that for you.
