altima wont go
Old 11-12-2007 | 03:57 PM
jrkread's Avatar
Default altima wont go
ok i have a 1997 nissan altima that i cant figure out ,the carvstarts right up and runs perfect and you can rev it up in park and neutral but as soon as you put it in gear it idles rough and if you step on the gas it bogs out and wants to die and barely moves at all it goes to about 1000 rpm and just drops and wants to die ,there are no codes the check engine light is not on i replaceed the tps,cleaned the trottle body and maf replaced spark plugs and wires checked the distributor its fine,there is a huge exhaust leak at the flex pipe before the cat i dont know if this would affect the car like this but i dont know any suggestions would be great. thanks
Old 11-28-2007 | 08:34 PM
2ndnissan's Avatar
Default RE: altima wont go
sounds like a problem with my 2004 altima ... what did you find for a solution?
treeman7691
01-30-2009 11:30 PM
jrkread
11-10-2007 12:05 AM
peterr22
04-02-2007 03:29 PM
brickey1
10-01-2005 01:12 PM
merc1100sc
05-19-2005 02:47 AM
