best way to remove oil plug nut?
i am having trouble removing the oil plug nut in my 1999 altima gxe. i've tried monkey wrench and a socket wrench. the nut is almost rounding. whats the best way to remove the nut??
RE: best way to remove oil plug nut?
If it is that damn tight I would spray some Pb Blaster on it......the best tool to use is a regular wrench, just make sure you are using the right size.
