Brake pad recommendation?
I need tor replace the front brakes on my 03 Altima. Can anyone recommend a set for me? Thanks in advance.
RE: Brake pad recommendation?
well u wantin performance or everyday driver pads? performance- brembo. oem replacement- go to oreilly auto parts and get u a set of their wagner thermo quiets. they have a life time waranty, prevent as much brake dust, dont squeel as bad as normal pads. jus be sure to replace or get ur rotors turned or ur pads might not last that long.. and not to mention it would void the waranty on ur pads.
i had my new brake pads replacements for my Murano...i loved that car! look for nissan performance parts available that will give you satisfying parts..
I have had good brake jobs on three cars. Did all the wrenching myself.
Hawk front HPS series brake pads are top notch in my opinion. Plan on a clean up cut on your rotors and also consider replace with new. If you look for serious stopping WET OR DRY consider their ceramic pads and cross drilled/slotted rotors. Cost a bit more but good insurance! |
if your just a normal driver go for the wagner pads wich are quite, perform welland affordable. if your into hard driving and brake hard alot then go with hawk or ebs brake pads.
What do you guys think of bendix pads?
Im concerned about higher mineral content in non-oem pads... |
I heard about Bendix pads but I'm not sure how good it is.
For an average driver, you can go with any make of brade pads, it wouldn't make much difference. But if you're a hardcore driver, then that's something different...
For an average driver, you can go with any make of brade pads, it wouldn't make much difference. But if you're a hardcore driver, then that's something different... |
If you want to information then please visit here http://www.starmarineinc.com/content/boat-storage
| All times are GMT -5. The time now is 02:40 AM. |
