Headlights will not stay on
Old Jul 10, 2009 | 04:16 PM
Beth's Avatar
Default Headlights will not stay on
I'm having an issue with my headlights, among other things. Here's what is going on:
*Headlights will not stay on. when I turn the headlight switch, nothing happens. I have to pull the lever toward me and hold it in order for the lights to come/stay on.
*When I turn off the car, the dinger for keys left in ignition/headlights on dings...even though neither of these is true.
*Running/tail lights stay on
I have to pull the tail lights fuse to make the two above things stop.
So any idea as to what may be wrong? Thanks in advance for any help!
1997 Nissan Altima
Old Jan 20, 2010 | 12:46 AM
Vultures's Avatar
I think the problem is in your high beam switch. there is a short in it and it needs to be replaced. Or maybe the replacement headlights.
Old Jan 26, 2010 | 08:21 PM
full house's Avatar
Is it new? maybe you need to replace it... I have similar problem couple of years ago!I just replace it and sold the old one for a cheaper price.
Old Feb 5, 2010 | 09:28 PM
04goat's Avatar
yep it sounds like the head light switch has gone out. now for the brakes you will have to get underneath the drivers side under the steering wheel. up under the console there will be a switch that the brake lever, not the pedal, but the iron lever. it will have a piece sticking out and when you push in the pedal the brake lights will come on. let off and the lights go off. if they are staying on then you will need to either replace the switch, or readjust the switch. either is not very hard at all.
And this happens all the time with older cars. but the headlight switch is another whole deal if you have the push pull switch then you will have to take off the **** by pulling it off . or by loosening a set screw. then you will need to take off the thin nut and the switch will come out at the inside. on some applications you will need to write down the color of wire off of what prong it comes off of. and the newer cars have a plug that is easy to get off and back on. if you have any questions let me no...
Old Apr 27, 2011 | 01:22 AM
kidashley25's Avatar
you can get a new switch installed about $400. it's the multiuse switch on the high beam or turn signal indicator...
___________________________
REPLACEMENT HEADLIGHT ASSEMBLY
hollywood6318
Oct 11, 2014 11:29 AM
jesica1980c
Off Topic
Aug 10, 2011 09:14 AM
jesica1980c
Off Topic
Aug 2, 2011 01:25 AM
jesica1980c
Off Topic
Jul 23, 2011 10:43 PM
RobinD
Jun 9, 2008 03:15 PM
