I wanna change my wheel 16 to 18 inch of my Altima 07
I purchase myAltima07 last week.
My current tire is. 215 60 R16. I wanna change my wheel 16 inch to 18inch. I have some of the questions to ask u guys. 1. What is the bolt pattern of the Altima? 2. What is the weight of the current wheel and tire(stock wheel)? 3. What is the tire size? 4. How heavy should the new wheel and tire? 5. Woudl you recommend me some of the wheels that look good on my new Altima? Thank you |
RE: I wanna change my wheel 16 to 18 inch of my Altima 07
The bolt pattern for your car is 5x114.3 with a 42 offset. I don't remember the weight of the stock rims off the top of my head, but unless you are racing, it's not a big deal. The tire size is something that you should definitely keep in mind.The big deal is that if you change the overall diameter of the wheel/tire combo that your odo/speedo will be off. There isn't any way to correct this currently. As far as finding new wheels/tires that will look good on your new car, check out www.tirerack.com , because they havea garage feature that will let you see what the rims will look like on your car (assuming you don't drop it, which with most rims, I would suggest).
| All times are GMT -5. The time now is 09:08 AM. |
