instrumen cluster light flickers and gera shifter problem
hey,
im trying to see if i can repair some problems on a 97 altima. anyone have or know where i can look at wiring diagrams for the car. the instrument cluster light turns on and off while driving, intermittent . and the gear shift light never comes on. has anyone had that problem. also which fuse is the cluster hooked up to, also the gearshift light. thanks! |
You are suffering with so many problems ,its better to go to a good mechanic and get it solved.I think after that you car will run in good condition.
