| HXC_Nismo |
Sep 23, 2005 10:26 PM |
RE: pcv valve and vapor canister
the pcv valve is really simple to do its just pushed into a rubber grommet on your valve cover with a rubber hose connected to it, takes no more than five minutes to do. the canistor on the other hand, is under the car by the fuel tank its a black square plastic box and it is bolted up the the body and a few hoses and possibley a couple of electrical connectors if i were you look at it first and if you feel comfortable to do it go for it but if you dont just get it done by a proffesional. but if you do do it make sure to pull your fuel pump relay and or fuse before you start just for safety percautions.
