-   -   Rough idle - 2001 Altima (https://nissanforum.com/forum/nissan-altima-10/rough-idle-2001-altima-3685/)
Umpire727 May 14, 2007 11:58 AM
My Altima is experiencing a rough idle when at stop. The CEL came on about a week ago and the code stated a Cylinder 4 misfire. I've change the spark plugs, fuel filter, and cleaned out the throttle body, combustion chamber and intake manifold.
The car feels like it is going to stall with the RPMs jumping, but at soon as I give it a little gas or turn the AC on high, the RPMs level out.
Any ideas? I would hate to take the car someone and get ripped off if it is something that can be done at home.
Thanks
pdbrains May 14, 2007 08:03 PM
RE: Rough idle - 2001 Altima
My Altima does a similarthing. At a stop, after idling ok for about 30 secondsthe idle turns roughand the rpms drop. The CEl will come on and then go off after a while. Got a code PO300, random multiple misfires and cod PO102, airflow sensor error- low air flow. It's going back to the dealer for repair. When I find out what they fixed I will let you know.
Burnnout May 15, 2007 07:57 AM
Umpire727 ... I would guess Throttle Position Sensor.......pdbrains... I would say Mass Air Flow Sensor.
Umpire727 May 15, 2007 08:57 AM
Sounds good! I'm going to see what codes pop up for mine today.
Thanks.
Burnnout - Is this an easily fixable problem?
Umpire727 May 15, 2007 08:58 AM
p0rt0_24 May 18, 2007 02:08 PM
i had the same problem and i just replace the distributor and the wires and the car appreciated it ;).
Burnnout May 21, 2007 08:52 AM
Honestly... I would take the car to the dealer and have them diag. it..... could save you money in the long run.
deb3360 Jun 7, 2007 09:41 PM
it could possibly be the intake manifold gasket, check the intake near #4 cylinder see if you hear a vacuum leak in that area or you could possibly see part of the gasket blown out
p0rt0_24 Jun 8, 2007 08:36 PM
i brought my car to the dealer he did like i said on my previous message.
