weak spark
Hi everyone. This is my first post to this forum.
I tried the “SEARCH” function for “weak spark”, it didn't return anything related to my problem. 1995 Altima 2.4L When the engine is cold it often won't start and floods. The only thing I find is a WEAK SPARK while cranking. Once it starts it runs fine. The distributor, ignition module, ignition switch and coil check out ok. Anyone run into the same problem or have any ideas? Thanks in advance, Phil |
| All times are GMT -5. The time now is 12:20 AM. |
