Weird sound!!
everytime i get off my car and shut my door i hear this squeak sound coming from my front area. I have no idea where the exact sound is coming from but it is very close to the front wheel area... any idea?? or should i just take advantage of the 100 point Nissan courtesy check up thingy...?? any suggestions will do, thank you all.
RE: Weird sound!!
You only hear the noise while the door is moving ?
RE: Weird sound!!
get some wd40 or some type of teflon lube spray and open your doors and spray the all the hinges and that should fix the noise if your hinges are all dried up unless you were in accident that caused your fender and door to rub wich i doubt the way you described it.
RE: Weird sound!!
the sound comes when i shut the door, when the door closes i hear that moment of high pitch squeak sound...it is driving me crazy sometimes...and i did try the wd40 on all the hinges...but the sound came back after a while and i was never in a accident. and thank you guys for replying
RE: Weird sound!!
go to the auto parts store and find a teflon lubricant spray or white lithium grease aresol spray can and one of those two should last alot longer then wd40 but at least now you know what exactly is causing that noise
RE: Weird sound!!
try to spray some oil on your nissan body parts try also to see if your door is rusty.
RE: Weird sound!!
I found other symptoms too, today i was driving on rough road bunch of small pot holes, i was driving slow but time to time i could hear that high pitch squeaking sound while driving... could it be my shock or my struts?
RE: Weird sound!!
ORIGINAL: latae84 I found other symptoms too, today i was driving on rough road bunch of small pot holes, i was driving slow but time to time i could hear that high pitch squeaking sound while driving... could it be my shock or my struts? |
RE: Weird sound!!
I know this sounds crazy but it worked for me. My car was squeaking every time I shut my door or drove over gravels or a bumpy road. Have someone press down on your hood while you shut your door. Every time someone would do this my car would not squeak. I found that when I adjused the two rubber pieces on the hood the squeaking stopped. When you raise your hood you will see two black rubber pieces that keeps your hood from rubbing. Once I adjusted these my squeaking completely stopped! Hopefully, your problem is as simple as mine was.
| All times are GMT -5. The time now is 07:32 AM. |
