2006 armada sputtering in hot temps
Hello,
I have a 2006 Nissan Armada with 190k mile on it. Problem started last summer in temperatures above 85 degrees it will sputter real bad after it has been idle for a few minutes it is a pretty bad jerk when it happens......you can turn the ignition off and right back on and the problem goes away. It went all fall and winter and did not do this and now that the temps are up in NC right now it has done it for a few days strait. Thanks |
