Remote start causes radio issue
When I use my factory remote start the radio has no audio. It’s on and functional (presets are there, nav is on) but no sound. And when I hit ‘seek’ it just keeps searching like the antenna is not active it I don’t even hear static.
Everything works fine if I start it manually. There is a TSB about ‘intermittent no audio’ but the dealer says this is a different issue from that TSB and would need a diagnosis starting at $168. Ive seen this issue in Ford trucks and GMC SUVs and most people are saying a computer ‘flash’ or software update usually solves the problem others say the head unit needs replacing but I can’t see that since it’s only a problem when remote start is used. 2014 Nissan Armada Platinum 78k miles |
Dealer should know there is a free TSB that addresses this exact issue, a design flaw impacting some vehicles. Tell him you want TSB-5688-221 incorporated and its free..
I have run into this numerous times as I am a certified chief senior Nissan mechanic |
Dealer doesn’t know that TSB
Originally Posted by Brancasio_chief_senior_mechanic
(Post 49708)
