96 nissan xe 4x4 headlight problems
Old Apr 2, 2008 | 08:17 PM
nissan4x496's Avatar
Default 96 nissan xe 4x4 headlight problems
I have a 1996 Nissan XE 4x4 with the k24e motor. It has been a great truck. I purchased it in 2001 with 52,000 miles on it, which we all know is nothing, and now have 173,000. All the miles have been pretty much trouble free but now I have a problem with the headlights. I have seen some of the postings and they all say it is the switch. I replaced the switch and it still did the same thing. So now I am thinking it is a ground problem. I just can not seeme to find the loose ground. My guess is I may have to dismantle the wiring sleave and check all wires, but I want to avoid that. Here is the situation. I will turn the headlights on one day and they are fine. Then the next they do not turn on. I have noticed that sometimes I will swith the lights on and after a second or two they turn on. I guessing a relay but I am at an end. Any suggestions.........
Old Apr 3, 2008 | 11:26 AM
joker7779's Avatar
Default RE: 96 nissan xe 4x4 headlight problems
Go with the relay because it is easy. I imagine that you checked the fuses and the switch plug on the vehicle side. Good luck. I have that same engine and I need to know if it came equipped with a fuel evaporive canister. If you are looking at the front of the engine it should be onthe right. Any info you can end my way is appreciated
Old Apr 4, 2008 | 07:56 PM
I think I found it. Is it a little blue fuse, about the size of a cigarette lighter...............I checked around and did a little research on the fuel evaporator canister and could not find anything on it. Some vehicles came with it but I don't think the ka24e motor, released in the hardbody, did not come with one but I'll keep checking because if it has one I would want to know.
proho
Oct 26, 2007 05:41 PM
DubyNX2000
May 9, 2007 02:29 PM
toddulous
Feb 9, 2007 07:16 PM
PLac
Dec 1, 2005 03:03 AM
Muspos
Sep 9, 2005 09:11 PM
