-   Nissan Forum Help & Suggestion Center (https://nissanforum.com/forum/nissan-forum-help-suggestion-center-7/)
-   -   Can't remove instruments cluster bezel. Help (https://nissanforum.com/forum/nissan-forum-help-suggestion-center-7/cant-remove-instruments-cluster-bezel-help-17246/)
TheCROW Sep 29, 2020 08:10 AM
Hi All,
I'm trying to remove the instrument cluster from my 98 Pathfinder to get it checked as it's gone haywire.
The problem is I cannot seem to remove the bezel because there isn't enough clearance between the dash and the steering wheel.
I do have the steering wheel tilt all the way down, but it need to go down more so I can remove the bezel. Am I missing something?
Beside releasing the lever and tilting the steering wheel downwards, what can I do?
Thank you.
EDIT: Issue resolved, I managed to pull it out straight towards me.
