Noise
Hello All,
I have a 2010 Nissan Altima Coupe and I have wind noise on the driver side window. I had the local dealer do test and the found the problem. But now its back. i called them back and the tech stated that it was a design issues. Sounds like BS to me. Has anyone else had this problem? If so how did you fix it. Thank you.:mad: |
hmm, did the sound look better than before if yes it must be the design.
It didn't make that noise for a year. How can it be by design?
But if you guys have not had this problem. the winter season is coming up and i'm hoping that water will not get into my car. i'm having it serviced on Friday i'll have them look at it again and i'll test drive a new one. Just to see if that noise their. Thanks guys. |
If you smoke take your cig and put it around your window inside the car..if you don't smoke get someone who does to light you up one and sit there and see where the smoke get blown away from the windows out line..then take it from there. At least you will know where to start your Quest..
WheelBrokerAng :) |
Noise
Guys, it was the window track. it was bent they replaced it and the noise is gone. this was not a design like they said the first time. Thank you all for your input and you help.
--Schroel-- |
hmm, I haven't though of that, good think they figure that out fast.
| All times are GMT -5. The time now is 10:35 AM. |
