| shane.roy81 |
Jan 19, 2011 10:10 AM |
throttle issues
have recently had the plugs replaced in 04 maxima se. since replacement have started to hear a high pitch squeel under load between 2500 and 3000 rpms. have checked all gasket seals and they are still good. am also getting an influx in rpms while driving, mostly in 2nd gear (seems to go out of gear rev up to between 4-5k rpms and then drops back down and goes back to normal). check engin light came on with a 0507 code. any idea what it could be and what to replace
