05 Frontier LTP indicator?
Newbie here. Does anyone know how to reset the low tire pressure indicator on the 05 Frontier? Any help appreciated.
Thanks, Tom |
RE: 05 Frontier LTP indicator?
My dealer's service department said it has to be done by the dealer... Mine was indicating low pressure - the dealer told me to bump up air pressure to 35-36 lbs - that took care of it.
My dealer told me to do the 36 lbs as well but it still didn't work. I think that I may just run it in and let them do it or just put up with the indicator.
Does it blink when you start the engine and then stay on or does it go on after you've gone down the road a bit??
If it blinks that means that it does need to be reset....if it is the other problem you may have excessive vibration like I did. One of the guys that I talked to about it said it may have something to do with harmonics in the engine. |
| All times are GMT -5. The time now is 10:04 AM. |
