97 Pickup-Swirl Control Valve Control Solenoid Valve
Where is the Swirl Control Valve Control Solenoid Valve. I have a code P1130 and thats the sensor that seems to be the problem.
RE: 97 Pickup-Swirl Control Valve Control Solenoid Valve
is that part of the evap system?
It may be but I can't get any information on it on the web.
i believe that it is part of the evaporative system, which is (on most vehicles that i have dealt with) around the tank...
I went to the dealership part department and talked to them. They said it was a sensor on the intake and it costs $182 but he recommended that I replace all of the vacuum hoses and visually check the wiring before purchasing the sensor. I'll give it a try and report back but I won't be working on it until Wednesday 09/14. The truck runs great it's just the engine light is on and my county won't inspect it with the light on.
I bought a subscription on the web from eautorepair.net and all the information I needed to trouble shoot. It ended up being a short in a wire going to the sensor.
