-   -   air conditioning fan (https://nissanforum.com/forum/nissan-frontier-19/air-conditioning-fan-2134/)
trofro Jul 15, 2006 06:42 PM
My fan blower only works on the number 4 position. Is this an internal fuse or a part that can replaced? Help please~!
finity Jul 17, 2006 04:20 PM
RE: air conditioning fan
I had this problem with my '02 Frontier. Behind my glove compartment, near the floor, there is a resistor board that controls fan speed. I removed this, and found that one of the traces on the resistor board was not working anymore. I did research and aparently these things rot through because they were poorly designed. At first, I soldered a new wire in to fix the problem. This worked for about 6 months. I found out that my dealership sold a replacement board for about $30 I think. I bought that, and it was pretty easy to replace.
Good luck!
hamiltono Dec 8, 2006 12:45 AM
guys, i have the same problem with the fan. can you be any more specific about finding the circuit board to replace? didi it work for trofro?
Burnnout Dec 11, 2006 03:40 PM
It is a blower motor resistor..... located under the passenger side of your dash... look up , there it is.
