kasunwck |
11-28-2022 12:05 PM |
Nissan-Frontier,Maxima,Pathfinder,Sentra,Xterra Gas Cap and Fuel Cap
Replace Gas Cap and Fuel Cap 17251-79961 Compatible with 2001-2004 Nissan-Frontier,Maxima,Pathfinder,Sentra,Xterra,350Z.2002-2006 Infiniti-G35,135,QX4.etc.
Product Description
🚙Are you still worrying about not being able to find a suitable fuel cap? Our high-quality fuel cap will solve all problems for you! Most fuel caps are sealed by turning them until you hear a clicking sound. An old, loose gas cap, cracked or otherwise faulty gas cap may causes your check engine light CEL turns on.
🚙If your check engine light comes on or if you smell of gasoline or diesel vapors around or near the fuel filler cap and your car is not smoking or making a unusual noise, please take a minute to check the gas cap.
🚙This gas cap provide a tight seal to keep your vehicle's fuel tank closed, fuel economy and reduce vapor emissions.
🚙100% brand new, ready to install out of the box. Please confirm your vehicle information in the compatibility section and the description below.
Compatible with Infiniti Vehicles:- 2003-06 Infiniti G35 Gas Cap
- 2002-04 Infiniti I35 Gas Cap
- 2002-03 Infiniti QX4 Gas Cap
Compatible with Nissan Vehicles:- 2001-04 Nissan Frontier Gas Cap
- 2002-03 Nissan Maxima Gas Cap
- 2002-04 Nissan Pathfinder Gas Cap
- 2003-06 Nissan Sentra Gas Cap
- 2000-02 Nissan Sentra Gas Cap
- 2001-04 Nissan Xterra Gas Cap
- 2003 Nissan 350Z Gas Cap
Replaces Part #:17251-79961 gas cap for.
PRICE = $25.99
BUY NOW AND PRODUCT LINK =
https://amzn.to/3GWqIpl
Sell on Amazon
If you buy this product using the above link, you will get this special discount under this link
About this item- 🚙THE ROLE OF REPLACING THE FUEL TANK CAP:Most fuel caps are sealed by turning them until you hear a clicking sound. An old, loose gas cap, cracked or otherwise faulty gas cap may causes your check engine light CEL turns on. If your check engine light comes on or if you smell of gasoline or diesel vapors around or near the fuel filler cap and your car is not smoking or making a unusual noise, please take to check the gas cap.
- 🚙COMPATIBLE WITH INFLNITI&NISSAN GAS CAP:2003 Infiniti G35 Gas Cap | 2004 Infiniti G35 Gas Cap | 2005 Infiniti G35 Gas Cap | 2006 Infiniti G35 Gas Cap | 2002 Infiniti I35 Gas Cap | 2003 Infiniti I35 Gas Cap | 2004 Infiniti I35 Gas Cap | 2002 Infiniti QX4 Gas Cap | 2003 Infiniti QX4 Gas Cap | 2001 Nissan Frontier Gas Cap | 2002 Nissan Frontier Gas Cap | 2003 Nissan Frontier Gas Cap | 2002 Nissan Maxima Gas Cap | 2003 Nissan Maxima Gas Cap.
- 🚙RELIABILITY AND DURABILITY : Professional, high quality OE style and meet or exceed all original equipment performance fuel cap. Provides a tight seal to keep your vehicle's fuel tank closed, safety your vehicle's occupants, fuel economy and reduce vapor emissions.High performance,Long Service Life,Made Of Reinforced ABS Plastic And High-Quality Sealing Rubber,It's More Resistant To Cold And Heat,1 Year Warranty, Worry-free Return And Refund Policy, Buy With Confidence!
- 🚙HIGH-QUALITY PRODUCTS:100% brand new, ready to install out of the box. Without going to a local auto repair shop, you may be able to solve your air cap problem, saving time and money.This is NOT a genuine part, it's a aftermarket replacement part.Please confirm the OE of your model and parts before buying, so as not to buy wrong.
PRICE = $25.99
BUY NOW AND PRODUCT LINK = https://amzn.to/3GWqIpl
Sell on Amazon
If you buy this product using the above link, you will get this special discount under this link..
THANK YOU.
https://cimg1.ibsrv.net/gimg/nissanf...fddefec7a9.jpg
