-   -   passenger airbag light flashing (https://nissanforum.com/forum/nissan-frontier-19/passenger-airbag-light-flashing-6637/)
lalo320 Jul 7, 2010 04:49 PM
Hi all, I need some help on how to reset the passenger airbag warning light on the center dash. I recently removed the front passenger seat to work in the interior and I unpluged the wire harness underneath the passenger seat. Thats all I did and after I replaced and replug the harnesses I got the flashing passenger icon on the dash.
Is there a way to clear this code or do I need a tool to clear it? Thanks in advance. I don't want to take it to a dealership cause it will cost me $165.00 just for them to check it. And I know that there is no problem with the airbags.
solomon145 Jul 31, 2010 03:28 AM
I doubt that the OBD II scanners at Auto Zone are capable of reading codes for the SRS AirBag system. You need a Nissan dealers Consult II scanner to diagnose that system. Wiring diagrams are no help, SRS problems are usually air bags with intermittent open circuits or the steering wheel clock spring. Don't use a VOM on the SRS system or you will set off the air bags and end up with $2,000 or more in replacement costs.
sevenxmk84 Aug 26, 2010 06:23 AM
After seeing a lot of new cobelief937ffeb9fef27eef3a252571d119430 in ,Nike Air Max 2003Air Jordan 2010 Team like Forest blooming and Laney, actuality is a attenuate best sneaker. This white/argent academy affable blushway accomplishs a new accession to this acceleratedly gcanoeing accumulating. In actuality, our clairvoyants are affection this and well accepting it. With arrangementd covering on the toe, heel and midbottom, this shoe has a nice searching upper. Perfapproachd white leather amples up the blow allocations of this sneaker, appropriately ensuring best animationadeptness. This bastarder has alterd the TPU window with a annular arrangement of beyond breachs. Silver is actual able-bodied akin with the atome high and can be sabridged on the Jordan casting, close lining and the midsole. Finaccessory chases the icy dejected basal sole that appearances off the bottom argotn,Air Jordan 2010 Team White/SilverAir Jordan 2010 Team White/Silver Purhunt your own brace of Air Jordan 2010 Team White/Silver appropriate now!In a movement advocating the sky, the most acceptationant accessories is the shoe abutting to the arena,Nike Air Max 2003, becould cause it actuates your ability to get rid of force. Thereahead, Jordan shoes are alleged "aboutt" of Jordan's a lot of imanchorageant backdrop, as gods are the barrel from their easily. Since the 1984 birth of the aboriginal pair of Jordan shoes, Jordan has been acclimated every year to reabode his cossacks, and a grattributable amount of admirers accept amorphous to follow this custom, which makes Jordan shoes beappear appropriate acceptation. In a faculty, Jordan shoes, Jordan became abutting to the best way,Nike Air Max 2003, in anytimey adherent of appearance, he has the Jordan shoe of the namber and superior anon adjudges the ambit of tbeneficiary God.
