X-trail Head light retrofit
Hi All
Here is a step by step with a few photos’ on how I retro fitted my lights. This is the projector that I fitted to this light. http://img246.imageshack.us/img246/6...ctorou0.th.jpg First I removed the light assembly from the car. Then removed all the rubber bits from it: Back Plug & Rubber D strip. Heated the oven up two 200deg C. Turn oven off, and placed the light assembly in for 5 minutes. Removed the hot light assembly from the oven and then using a knife, slowly prized the clear lens away from the body. http://img246.imageshack.us/img246/2...ovenbx4.th.jpg http://img246.imageshack.us/img246/1...ovenns3.th.jpg Once apart, I placed the clear lens somewhere safe from being scratched. Then I unscrewed both light aiming screws and popped the light reflector off it pivot point. The light reflector is what I used to mount the projector. So I made a template of the bolt holes and the centre hole required on a piece of cardboard. Then transferred that across to the back of the reflector. http://img246.imageshack.us/img246/9...e008ne7.th.jpg Then using a dremel, I cut the holes required. I dry fitted the projector before painting the silver side of the reflector with matt black. http://img246.imageshack.us/img246/6...e009ii7.th.jpg While waiting for that to dry, I added washes to the bolts to space the projector from the mounting base (the old reflector). The spacing required was about 15mm on all. Then using moldable epoxy, I mounded 4 feet that the securing bolts would use. http://img246.imageshack.us/img246/7...e011wj1.th.jpg Once that had hardened, I fitted the projector, use locktight on the nuts & cut off the excess thread. http://img246.imageshack.us/img246/6...e013ve2.th.jpg Then fitted the unit into the back housing, and reattached the adjusting screws. http://img246.imageshack.us/img246/2...e017ku8.th.jpg Heated the oven back up to 200, and did a reversal of the above to remove the lens. The addition of silicon to help reseal wasn’t required, as there was plenty of original goo there. Now I fitted the unit back into the car, hooked up the light and adjusted the position to suit. There you have it. http://img246.imageshack.us/img246/7...e018yz2.th.jpghttp://img246.imageshack.us/img246/8...e019ka3.th.jpg For those that have picked up that I haven’t fitted a shroud over the projector. I still haven’t decided on what to use. And to remove the light and oven open it again will only take 15mins. So that’s the reason why. |
| All times are GMT -5. The time now is 06:13 AM. |
