02 max in need of help
Old Feb 6, 2010 | 06:10 PM
al odom's Avatar
Default 02 max in need of help
i have a 02 maxima and the service engine light is on i checked the codes and they read PO335, PO725,PO725pd,335pd. the problem is with the crank sensor when plugged in the car cranks but runs at a low idle and with it unplugged it turns over for a couple seconds and then crank. it runs fine after that. i was told that a new motor was put in. could anybody give me some help solving this problem
Old Feb 11, 2010 | 08:27 PM
full house's Avatar
maybe the engine is not working properly or malfunctioning...how old is your 02 maxima?
Old Feb 18, 2010 | 03:58 AM
chike's Avatar
p0300
p0455
p0152
p0158
The above error codes appeared in 02 maxima although i changed another used engine am not very sure if the milage is as truth as the dealer sold it to me. please
what do i do.
Old Sep 18, 2012 | 05:33 PM
Eltyson Cortez's Avatar
que se puede aser con el problema del po725
Sevorg1
May 15, 2006 03:45 AM
jmart2221
Apr 23, 2006 08:53 PM
ntxmotorsports
Aug 5, 2005 04:51 PM
marketapex
Jul 30, 2005 06:16 PM
stevemcintosh
Jun 13, 2005 05:57 PM
