02 max in need of help
i have a 02 maxima and the service engine light is on i checked the codes and they read PO335, PO725,PO725pd,335pd. the problem is with the crank sensor when plugged in the car cranks but runs at a low idle and with it unplugged it turns over for a couple seconds and then crank. it runs fine after that. i was told that a new motor was put in. could anybody give me some help solving this problem
maybe the engine is not working properly or malfunctioning...how old is your 02 maxima?
p0300
p0455 p0152 p0158 The above error codes appeared in 02 maxima although i changed another used engine am not very sure if the milage is as truth as the dealer sold it to me. please what do i do. |
que se puede aser con el problema del po725
| All times are GMT -5. The time now is 12:36 AM. |
